Dajazar's mk1 Sterling (formerly Rich Moss')
My plan was to check balljoints first. I'm going to get it up on axle stands, undo the track rod ends and see how each leg feels. Then, if it's not immediately obvious, I'll undo the bottom balljoints and see how they look and feel.
The rack seems to be OK but the 8 month old bottom balljoint on the right hand side seems to be partially seized. There's plenty of grease in it, it's just sticking.
I've got it in bits now, just need the joint.
I swapped that balljoint but it didn't make any difference after all. So I had another go today and replaced the PAS pump with a used spare I had in the shed. It may be better - but I'll need to give it a quick road test tomorrow. I think that the old one was just not giving enough oomph.
I also found that the rack gaiters were showing signs of old age - one was split and the other had gone - so I've changed those (well, one as it started to rain before I got the other done).
As an aside, why do Honda make it all so ****ing difficult to get at? To get to the bottom mounting bolt for the PAS pump you have jack the engine up and remove the engine mounting bracket. To get to the inner end of the driver's side gaiter you have to remove a cover plate and work in amongst all the pipes and hoses for the rack (which the Rover rack has on TOP of the rack and therefore out of the way).
Anyone want to buy a manual mk1 Sterling? I'm serious, by the way.
- Seans Dad
Too true Richard.Richard Moss wrote:As an aside, why do Honda make it all so ****ing difficult to get at?........ To get to the inner end of the driver's side gaiter you have to remove a cover plate and work in amongst all the pipes and hoses for the rack
When I did my rack gaiters last month, it took me almost half an hour to do the drivers side, because of that cover plate, but the passenger side took ten minutes to change!
Still, I suppose it keeps us on our toes..................
Dan.
1999 Mercedes C Class C240 Sport Auto Estate.
Previous Rovers: '94 827 Sterling Fastback Auto, '91 820si Fastback Auto.
http://www.mgt-dist.co.uk
Definitely for sale. My plan is to remove the LPG kit as I need parts of it for my mk2 and Phillippa's 216 and then replace the steering rack with a known good one.
Anyone interested at £250?
What's the state of play with MOT etc?Richard Moss wrote:Definitely for sale. My plan is to remove the LPG kit as I need parts of it for my mk2 and Phillippa's 216 and then replace the steering rack with a known good one.
Users browsing this forum: No registered users and 50 guests
