Despite fitting a new rear exhaust box a few weeks ago, and Brad fitting a new centre section before I got the car, the exhuast note has a deep reverberation and is getting quite unpleasant, so time to investigate.
I could not find any gas leaks, or really locate the source of the noise, but it did seem to be from the front - so the front pipe is the obvious suspect.
As usual, the forward bend has had a hard life and is heavily rusted, paper thin. That was enough to convince me I had to do something.
Having changed four or five front pipes on 827's I was not looking forward to the task - it can so easily escalate into a world of pain.
I had a good look at the manifold studs and as expected - this car is 26 years old after all - they were at an advanced level of crudiness. I got a small wire brush up there and cleaned as vigourously as I could to clean up the exposed threads as much as possible. Experience shows that the nuts usually start to turn okay, then seize on the rusty threads and shear off the stud.
Next I invested in a tin of "Plus Gas Dismantling Fluid". This is much thinner that good old WD40 and far superior in penetrating and easing rusted up fasteners.
I left that to soak, spraying them liberally 3 times over 24 hours.
This morning I gingerly pushed on the best quality , 6 face - 14mm socket in my set and started to swing on them. Miraculously they offered no resistance at all. They came off as if they has been on for a couple of weeks - amazing!. Two of them actually unscrewed the studs rather than the nut, but I am not complaining!
Of course this is a non-cat car and the last time I looked, front pipes were hard to find, and £140. Later front pipes for cat cars are easily had for £35, so what is the difference?
Top pipe of from Rebecca.
Middle is an almost-new used non-cat pipe - see the curious bend near the end section?
Bottom is a new Mk2 pipe
They are all slightly different lengths too.
The non-cat are only a few inches shorter than the later ones - the middle section is longer to make up for the missing cat.
Here is more evidence of noise from the pipe. See the bodged filler in the join and the blackend and rusted section before the flex.
Another view of the ends of the three pipes
and finally the rusted front bend
The initial plan was to cut-and-shut the new pipe to match the one of Rebecca,but a little more thought produced this:
[/url]
I didn't want to interfere with the new front pipe, so just cut the end off the orig pipe, which was in very good condition.
I can confirm it was the original factory item - double skinned!
Some careful measuring showed the gap between the new pipe and the middle section is 3 1/4". A bit of hunting in the scrap pile produced another old front pipe, so just cut the flange of that and welded into the other piece - Voila a perfectly formed spacer piece.
Just need to wait for the hail storms to pass so I can bolt it all back up, if I can find some gaskets in the shed..
Tim
