Hi all, I have only recently got my coupe to a standard where I am happy to take to show's and want to go to more since the BMC outing at Peterborough. The Hull show came up quite late and i was unable to adjust my work commitments so had to miss it. The Ashby Folville looked quite interesting as well.
Is it possible for one of the moderators/admin to create a tab dedicated for a show calendar where meets and show dates could be placed that way we can all see when they are due and try and make plans to attend. 2013 is probably nearly finished in respect of showing our cars (NEC excluded) so now would be a good time to start to populate a calendar with next years events.
Does anyone else agree with as an idea. It could also assist the the donation button for show finances?
show calendar
- rovercoup
show calendar
- simon
- Location: london (exbrumy me not jane) [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: show calendar
yes
Simon & Jane.
Rover 825sd 229,000.
Rover SD1 V8 VDP 126,000 will get running this year.
2 rover 75's
2 rover 75's
Re: show calendar
Sounds like a good idea - I'll ask James to look into it (I'm no use with the forum software)
- rovercoup
Re: show calendar
Thanks Richard. The Jag is coming on nicely I seeRichard Moss wrote:Sounds like a good idea - I'll ask James to look into it (I'm no use with the forum software)
- TDHFastback
- Moderator
Re: show calendar
Good idea Steve.
Hopefully be able to see shows that take place on days other than just Sundays.
Kate
Kate
Re: show calendar
We can create a calendar on the homepage in Wordpress. I'm looking to update the forum shortly as it could do with a bit of a refresh so I'll keep this in mind.
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mercedes C300 Hybrid
2015 Mini Cooper SD
m6jkk.com
Current Fleet
2015 Mini Cooper SD
Re: show calendar
In the meantime I have added this post in the Announcements and Events section: http://www.rover800.info/forum/viewtopi ... =5&t=11283
Please post details of shows as a "reply" and then the moderators can edit them into the first post.
