http://www.gocool.co.uk/index2.html
Mobile aircon chap (George) came to my workplace and carried out a variety of tests including a sniffer device that finds tiny leaks, diagnosed a bad pipe and told me a lot about air conditioning. I had no idea there was sight glass on top the dryer... anyway that was £45 for the callout.
Came to my house today, fitted the secondhand pipe I supplied, tested for pressure, did a vacuum that helps remove moisture and regassed (£40 labour and £70 for regas). He showed me how you can tell from the sight glass if the gas is low. When it was up and running he noticed the revs fluctuating when the compressor was kicking in and out so it nearly stalled, I told him it seems to do that so he speculated on a grubby throttle body and cleaned it out which did the trick. And no charge for that.
He does auto electrical as well so I'm going to get him to fit my facelift seats.[/url]
Go-Cool Services Bristol
- Tenesmus
Pete
