1935 morris 18/6.. resto/update/modernise
- thamestyres
Re: 1935 morris 18/6.. resto/update/modernise
the outlet at the bottom of the rad is to small and pointing at the alternator, need it coming out and upwards... hoping to get my rad man to come and look at it while its on the car.. not to difficult to do but he will have the right bits etc.. regards ricky
home of the "Mad Maestro"
- thamestyres
well the rad man he says "yes"... jag now fully stripped and gone... recovery truck now parked up in my driveway so no more moaning from my mum... just need to crack on with the job in hand now..
- thamestyres
I have not got very far with this, however I have done a few little bits.. and more recently I have made a start on the wings and inner wings which will (hopefully) be in one piece again, very soon, have chosen to rebuild the inner wings rather than make new ones, the main reason being I feel better to have as much of the original car as possible, upgrades being the exception off course, I may have to modify them further down the road but for now as std as possible.. the a pillar has been repaired, the n/s wing has been repaired around the headlamp mount, and the a pillar attachment.. the inner wing was almost beyond, but needed a new base where it mounts on the chassis and a new edge where the two wings join and a new end piece, just needs the main wing joint sorting out to join them together.. regards ricky
- thamestyres
bit more done it now has steering, the column is mounted and joined to the rack, quite easy in the end just extended the rod between the u.j's with a 3mm thick tube welded and cotter pinned for extra security.. the dash will need a bit more strengthening just in case, it is only screwed into wood so will make some support brackets for it.. regards ricky
That's good progress Rick! WIll it see tarmac legally this year or is it further off than that?
- thamestyres
I should be so lucky, lucky lucky... lol
Oh god, he's gone all "Kylie" on us! Lol
- thamestyres
I have spent probably the equivalent of at least a week rebuilding the wing on the n/s and it still needs more work, I was asking for some info/pics for the front where the wing joins the grill sort of area, and I get offered 2 front wings nervously I said how much? and to my surprise he said £50...…… the pair...……… trying not to be to excited I said i'll have them... where are you, Stranraer he replied..... an 800mile round trip.... in my Peugeot that's about £200 fuel plus b+b etc still cheap but almost beyond me... we tried to find a trucker to bring them down south, no go.... then he asked parcel force they said yes £50 the pair so I have now got (soon to be delivered) 2 front wings that don't need anywhere near the work that my wings need, and I am very happy and feeling rather smug at the moment.. hopefully will get some good work done with this soon... regards ricky
That's great news on the wings Ricky!
- thamestyres
I have got the wings which compared to mine are mint, inner and outer all one piece and a couple of light repairs and they are good.. in the lockdown I have been doing lots of welding and grinding and some more grinding and its grinding my nerves... lol the rear of the car is mostly stable now still have some grinding to do but it is getting there rear wings are rusty but not beyond and very simple to do, I have it on stands old axle off new axle ready to be aligned up and fitted, more welding and grinding, have built the front kick panel and trans tunnel, brake servo/pedals bolted down.. steering column fitted and tested.. have decided to fit air suspension all round, front is on the car, rear will be fitted with the rear axle then maybe a trip to hayes to see a man about a controller for the air suspension, have ordered some equipment for shaping the metal so I can do some more welding and griiinnding…. I hope everyone is keeping safe will no doubt see some of you at the shows when we are out of lockdown.. regards ricky
Looking forward to more pics and updates Rick!
Nice to hear from you Ricky. Glad you are keeping well.
- thamestyres
have fitted the jag axle still got the shocks to do, waiting for metal again,,,
it seems never ending but at least I can see things getting done... and hello SJG I am still alive and kicking
More great work Rick - do my eyes decieve me or is that air suspension?
- thamestyres
it is air suspension proper jag on the rear and shitreon on the front at the moment but have more work to do on the front might have to change them.. have been strengthening the rear suspension today... still waiting for more metal, so I can build the tops of the shox..
