Post by CHR15E » Thu Oct 27, 2016 5:41 pm
scoobyh123 wrote:Last year definitely proved my point sadly. Even in dry and non-icy conditions, people seem to take on a strange mentality where nothing else matters except what they want to do and they must get it done now if not sooner. We call it "Silly Season" here :wink: :lol:
Beginning to be like that all year round here lately.
Not sure if people have always been this way and I've ignored it or maybe I'm just getting old(er) and more grumpy? :D
Post by scoobyh123 » Thu Oct 27, 2016 6:04 pm
There's a good reason it got its name! :wink: :lol: :D
Perhaps we're both getting older and more grumpy Chris or maybe the general standard of driving is going downhill........... :shock:
Post by Marc-827-Vitesse » Thu Oct 27, 2016 7:18 pm
If you two are old and crumpy. :P Remember i am still wet behind the ears (26 yo) and drive very calmly in traffic. ;) Most people drive oke but after a day of driving you tend to forget the hundreds of people who were oke and remember those 5 who were not.
Traffic just becomes more full and people don't enjoy it nowadays and it is all about the destination and not the journey. You ar both right that it is not changing for the better in traffic.
Post by scoobyh123 » Fri Oct 28, 2016 4:50 am
Round my neck of the woods i tend to remember the 5 who drove ok, not that i often get anywhere near 5, usually just 1 or 2 as the rest were horrendous! :wink: :D
Post by CHR15E » Fri Oct 28, 2016 6:06 am
Marc-827-Vitesse wrote:If you two are old and crumpy. :P Remember i am still wet behind the ears (26 yo) and drive very calmly in traffic. ;) Most people drive oke but after a day of driving you tend to forget the hundreds of people who were oke and remember those 5 who were not.
I'm not 'that' much older than you. :P
I'm 35, though my other half says I'm going on 50 with all the moaning I do about people's driving. :roll: :lol:
Post by scoobyh123 » Fri Oct 28, 2016 11:34 am
Perhaps that's why i moan so much about others driving, i'm nearly (but not quite) twice Marcs age. Still the better side of 50 though! :wink: :D
Post by Marc-827-Vitesse » Fri Oct 28, 2016 1:31 pm
35 is still pretty young i agree. ;) You are as old as you feel Dave. ;) :)
i know what you mean Dave. Especially in rush hour there are more plonkers on the road. I am lucky i don't have to drive in rush hour but only drive my cars when i am not in hurry. If i would be driving in rush hour i would probably feel the same. ;)
Post by scoobyh123 » Fri Oct 28, 2016 6:03 pm
I don't drive in rush hour either Marc, just seems there are loads of plonkers round here! :wink: :D
Post by Marc-827-Vitesse » Sun Oct 30, 2016 10:37 am
Haha. Ah oke. I will not comment on that. ;)
(just a joke)
Post by scoobyh123 » Sun Oct 30, 2016 5:52 pm
Marc-827-Vitesse wrote:Haha. Ah oke. I will not comment on that. ;)
(just a joke)
:lol: :lol: :lol: :lol: :lol:
Post by Marc-827-Vitesse » Tue Jan 02, 2018 3:15 pm
In 2017 my SD1 Vanden Plas was mostly stationary because i wanted to save for the technical maintenance. In the mean time i did some cosmetic jobs. One of which was painting the dashboard. Maybe the old primer was reacting with the heat of the sun or something.
I took apart parts of the dash.
De-greased the das and used plastic primer.
Four coats of colour.
Some coats of clear varnish to improve the durability.
Wood back in
Off course there is a difference in colour because the rest of the interior has to be cleaned and the paint is new in comparison with the 35 year old interior. It is also more shiny but after the clean i use cockpit spray on the rest of the interior. If the result is not as durable as hoped i will let the dashboard be wrapped or something. But for now it looks fresh again.
On the last pics you can see that the black cover of the instruments does not fit wel at all and that it has the wrong colour. It is a part that causes many problems because they buckle, warp or change colour. A new one is no longer available for a left hand drive so i did my best. At first i tried to get a proper shape in the part and some strength. I used weights to straighten it out a bit and to glue the steel strip to the inside. I also made a plastic piece to give the corner some strength. I used a DVD box and cut out some plastic. I heated it with the help of a friend to make i shape that i needed and glued it in place.
First i glued te sky to the part again prior to paint. Primer first:
Then i used white to make sure the beige would pop more.
Colour:
Also clear varnish to hopefully give a durable result.
I still had to make adjustments after this to make it fit. It is a 100 times better than before but it could be better. Maybe use 3-D printer to make a new one. For now it is fine.
Last edited by Marc-827-Vitesse on Sat Apr 28, 2018 4:44 pm, edited 1 time in total.
Post by Marc-827-Vitesse » Tue Jan 02, 2018 3:24 pm
September 2017
During the storage awaiting technical maintenance i did a fun job as wel. During filling up the petrol tank i noticed that the Vanden Plas leaked fuel. To be sure i wanted a good replacement tank and filler pipe. A good tank and pipe were found and before putting it in the Rover i treated it to some TLC.
This is how it arrived. Not bad but some surface rust.
Gently sanded the surface rust of.
De-greased it and used rust remedy.
After a day i removed the exes and sprayed zinc spray to give a protective coating.Image
After this the tank was already properly protected but i wanted another coat and choose to use stone chip spray in the grey colour. The pipe on the tank i used black stone chip spray and satin black.
I used grey stone chip spray for the tank itself because original it was steel silver so grey comes close. :)
The filler pipe got the same treatment. Cleaned surface rust, rust remedy, zinc spray, black stone chip spray and satin black.
The rubber ring was cleaned and treated with vaseline.
Last edited by Marc-827-Vitesse on Sat Apr 28, 2018 4:45 pm, edited 4 times in total.
Post by scoobyh123 » Tue Jan 02, 2018 3:37 pm
Superb Marc! Almost speechless i'm that impressed! :wink: :D
Post by Marc-827-Vitesse » Tue Jan 02, 2018 4:01 pm
Thanks Dave!
In oktober and november me and my friend agreed that my Vanden Plas would get the maintenance it deserved. It is quite a list but it is quite an old motorcar. And i worked hard for it on the ship so...
This was the original list.
New radiator.
New cooling fan.
New viscous clutch
New waterpump
New belts
New gaskets and seals for the engine
New crankshaft seals
Rebuild transmission.
New rubbers in front suspension.
New rubbers in rear suspension.
New rear shocks.
Install new fuel tank.
New stainless steel rear silencer.
New tail lights.
New air hoses under the bonnet.
New cooling fluid.
New engine oil.
New diff oil.
New engine mounting rubbers.
New gearbox mounting rubbers.
Rimmer Bros parts came in.
Prior to the pick up i treated the rubbers and tires to a new coat of creme.
Mid oktober i let my Rover Vanden Plas be picked up and brought to a friend of mine who will do the maintenance. I could have drove the Rover Vanden Plas but the seals of the transmission were leaking badly and so was the engine. I don't want any oil on the road so i choose the safe way and asked professionals to transport my Rover.
The tow truck pulled the Vanden Plas out of the underground car park.Image
First sun in about a year!
Photographed from my dad's 827 Si.
Arrived safely. Good job by the tow service.
November 2017
My Rover SD1 Vanden Plas is in fairly good health again! As said the credit of the work has to go to a friend (who i paid of course). He also made some pictures.
This has been done:
1 Automatic gearbox rebuild. Even though the car has low miles (110.000 kms) i wanted to be sure it was oke.
Cleaned and rebuild!
2 New sensor that communicates with your starter motor and reverse lights.
No rust anywhere!
3 Rebuild the radiator to be sure. The old one was a bit tired.
4 New engine mounting rubbers.
Engine in the lift to replace the mounting rubbers.
5 New gearbox mounting rubbers.
6 New cooling fan.
7 New viscous coupling.
8 New waterpump.
New waterpump and viscous coupling in the Rover.
Rebuild radiator and new cooling fan installed.
9 New belts.
10 New rocker cover seals.
11 New inlate manifold gasket.
12 New gasket distribution chain cover (front of engine)
13 New crankshaft seal front and back.
An old crankshaft seal.
14 New rubbers front suspension.
15 New rubbers rear suspension.
16 New shocks in the rear.
17 New springs in the rear.
New shocks and springs installed in the Rover.
18 Replaced the petrol tank.
19 Replaced the fuel filler pipe.
20 New stainless steel silencer mid section.
21 New stainless steel rear silencer.
22 New air hose for under the bonnet.
Arrived in a piece of two meters.
23 New coolant fluid.
24 New engine oil.
The oil sump has been removed to check and clean. Re-installed with new gasket.
25 New differential oil.
The diff has been opened, cleaned and checked. Looked fine! New seal put in and new oil.
26 New fuel filters.
27 New filters for engine oil breathing system.
28 New distributor.
29 New rotor
30 New spark-plugs.
31 New spark plug kabels.
After this i collected my like new Rover.
32 New tail lights.
Nice and easy job to do myself. Makes a huge difference in looks and people will see you better. Left one is the old one.Image
Then i wanted to take it for a short drive to visit my brother. As you saw a lot of attention has been spend on a lot of systems and parts but not the alternator and by Murphy's law.......yeah.
*-) (:P) 8-)
33 New alternator.
After a wash and pampering.
New parts do make it look a lot better but the black parts like the air filter box have to be repainted.
Dash looks pretty good in the sun.
On my way back home from visiting a friend a made a nice pic in the shopping mal car park at night / late evening.
I adjusted the cable on the transmission to make it even better in shifting.
Almost winter time so time for hibernation prep.
Filled up the tank, drove the Rover up to temperature and a proper wash.Image
Took out the battery and attent to details with creme.
Old bed sheets to prevent the cover from scratching the paint.
The cover.
Last edited by Marc-827-Vitesse on Sat Apr 28, 2018 4:48 pm, edited 4 times in total.
Post by Marc-827-Vitesse » Tue Jan 02, 2018 4:11 pm
Like i said in the previous message; some parts in the engine bay needed TLC. I took out almost everything that is black and started.
Radiator protector. A bit shabby with surface rust and lack of shine.
Battery mounting bracket. Clear story.
Airfilter box dirty and shabby.
Cold/hot air regulator shabby.
The parts that had some rust on it i brushed them, sanded them, de-greased them and put rust remedy on them.
After a day i removed the exes and sprayed them with zinc spray.
Primer:
Air filter holders.
Battery bracket.
Cold/hot air regulator.
The radiator protector i did not use primer but stone chip spray to give it protection.
After this i coated every part with satin black.
Now i also took the opportunity to install a sticker that was missing.Image
Radiator protector looks nice again.
Looks pretty good i think.
Another nice touch for the interior.
Last edited by Marc-827-Vitesse on Sat Apr 28, 2018 4:51 pm, edited 1 time in total.
