I had a good play around on the beta site using my phone and tried some of the different skins. It works well, so really looking forward to the upgrade. What its taptalk? I saw it appear when I was looking at another forum sure but I did not know what out meant, this was on my n8, stop perhaps it might work?guru wrote:Probably the only phone I don't have access too! My brother had a symbian powered phone but it broke so he dumped it and bought an Android.
Sadly it doesn't look like taptalk is available for symbian so you might have to go through the styles until you find one that suits.
New forum development feedback thread
- Joined: Fri Aug 29, 2008 10:30 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
My bad, I reset a few passwords in testing, I'll pm yours nowMikeMedford wrote:From what I can see it looks good, can't test anything though as my login doesn't work
Edit: Also had a quick browse with my Nokia N8 and iPhone 3G and the site scales quite well on both with the standard browsers.
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mercedes C300 Hybrid
2015 Mini Cooper SD
m6jkk.com
Current Fleet
2015 Mini Cooper SD
Cheers, have looked through the various skins now and I personally like the se_sprites the most, however that skin and a few others (sub silver and serenity were ok) have an annoying habit of oversizing the posters info (where the avatar is) when viewed on fullscreen.
There should be a line of code in the skin somewhere which disables that section from resizing altogether, so it remains at avatar size permanently, I've had todo this with a forum skin before but for the life of me can't remember where that parameter is
