You may have noticed that the "Your Cars" section of the forum is chnaging. I have split it into a number of sections that (hopefully) make sense.
Obviously 800s get their own bit.
Then the 25,45,75 get a section (including derivatives such as the MGs and the bubble 200/400).
Other Rovers and "legacy" models have their own area (this includes ARG, BL, BMC).
The 4x4 and Non-Rover sections remain unchanged.
I've started moving threads to the relevant sections and will do more later. If in doubt, they have been left in the "800" section by default.
Please let me know what you think.
RM
More forum changes
More forum changes
- Alex SBY
- Location: Devon. [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: More forum changes
Good stuff, makes a lot of sense.
Only one issue though. The permissions on the 4x4 and other BL ones are not letting me view. I suspect you need to set them so non admins can view them. Try viewing the forum as "me" (you can do this via the ACP) and you'll see what I mean.
Setting permissions on PHPBB3 is a right PITA. I had this on AR forum when I set up a new board once!
Not a moan, just helpful feedback.
One or two 800s...
- Richard C
- Location: Gloucestershire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I hadn't noticed that until you mentioned it Rich, I always go straight to 'View new posts' so didn't see the new layout. All makes sense
@Rich_Clements
@Rich_Clements
- Very Tall Brad
Alex, it should be sorted now.
