bits 'n' pieces
- TDHFastback
- Moderator
bits 'n' pieces
Hi 800 experts
Just new to the site and have a couple of questions. Not sure though if I'm putting them in the right bit.
1 The pride of Longbridge Rally this week, is it like a proper car show with aftermarket/accessory/autojumble stands, places to eat etc or more basic ie cars lined up in a car park. Never been to a Rover show so not sure wether to bring sandwiches/flask or not .
2/ I fitted a windscreen finisher to my 1999 825 Sterling fastback. It was second hand and the rubber seal is quite brittle and has cracked in places so is not flush with the windscreen. Is this a problem re water getting were it shouldn't and causing a rust trap or will the water just drain away
3/ In the Rover accessory brochure they showed a large plastic/rubber boot liner with a HUGE rover logo embossed in it in a saloon. Will this fit the fastback and any idea where I might purchase one from if it does (or did Rover do one specifically for the Fastback)
4/The left corner of my front bumper is loose. Apparently down to a warped side bracket. Is it a big job to fit a new bracket and are they still available?
5/Whos the best people to try for genuine Rover branded accessories as listed in the accessory brochure such as fire extinguishers ,first aid kits etc.
6/ Does anyone still do Rover pearlescent BRG paint touch up sticks?
Quite a list but I'm determined to keep my beloved Sterling on the road and looking as good and genuine as possible.
Thank you so much and God Bless
Kate x
Kate x
- whitelion58
Hello Kate and welcome..
Cannot answer all your questions, but sure someone will be along shortly to chip in.
2) The water should channel away if it gets under the finisher, do not think they were ever intended to be water tight
3) Rimmer's sold off the last few boot liners cheap about a year ago I am afraid. They do crop up on ebay from time to time - I got one a couple of weeks ago in fact. I think (hope) they fit fastbacks the same as a saloon - can anyone verify? Not had chance to try it in any of my fleet yet.
4) Droopy bumpers are very common. It is the same bracket at all four courners - DPL10022 . Available from Rimmers or your local Xpart dealer for about a tenner each. Quite straightforward to fit, though easier with two people to lift the bumpers on and off.
Good luck with your car.
Tim
Tim
'86 825 Sterling Saloon
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
Welcome to Rover 800
This is the boot liner I have in my fastback, bought from Rimmer Bros last year. I seem to remember MG mal had a few last time we went to his barn??? though that was a while ago. Its made of plastic and is easier to get in with the shelf out. After changing the boot carpet three times I thought i'd better have one
Mk2 Vitesse Fastback
- Joined: Sun Sep 13, 2009 6:53 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I got one when they were going cheap,minor problem is the format is for the CD unit fitted on the LHS and in a saloon they are on the rhs if you look at the two sides you can see they are different. just needs a hot air gun to form the plastic on the rhs
300,000 mile white gold sterling on lpg Gone RIP
150,000 mile red sterling on lpg Still around
100,000 mile BRG rover sterling not on lpg Passed on
shiny blue jag on lpg
Another blue jag 2.5 auto
For left hookers then by the look of it?
The Longbridge is a large affair but no stands etc. All parked on a park. There's pics of last year in the show pics section.
Sandwhiches etc are a good idea.
I've never seen a CD changer fitted on the left - I can only assume that it would be an aftermarket installation that has been put on the left. There's no reason for it to be different as the boot area is the same on saloons and fastbacks.dead827 wrote:minor problem is the format is for the CD unit fitted on the LHS and in a saloon they are on the rhs
- Tenesmus
Try Rimmers for accessories (and paint, make sure you've got the paint code)
http://www.rimmerbros.co.uk
Pete
- mjc9967
I think original Rover paintsticks etc are all completely gone now. If they were still around, I'd be suspicious of their sell by date!
http://www.paints4u.com has been given good marks from some on here in the past. You just stick your paint code in and order paint sticks, aerosols etc. Prices look quite good too. Hope this helps.
...and welcome by the way
Re:
OK, digging out an old post. But I am able to pick up two of these tomorrow - one for me and one on offer. If it is as good as suggested I'd ask 30 quid for it (and should be able to deliver somewhere not too far from Dover or en route to Brad in late February or March)... So - who wants one?Slamm wrote:Welcome to Rover 800
Alexander
More cars then sense....
Re: bits 'n' pieces
Yes please Alex, allow me to check with Brad that he doesn't mind you dropping it there for me.
Thank you
Thank you
- gibbzy2k1
- Location: nr Cearphilly, South Wales [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: bits 'n' pieces
ohh wouldn't mind one of these. Probably a sod to fit in a coupe, if at all possible that is.
"Hey, let's be careful out there"
Callen
1994 Rover 820 Vitesse Sport *RIP
2005 MG ZS+ 115
1997 Rover 825 Sterling Coupe
1998 Rover 825 Sterling Saloon
Callen
2005 MG ZS+ 115
Re: bits 'n' pieces
Very useful items. I'm after one for a Mk1 saloon but these are apparently rarer than hens teeth. If anyone has one for sale or knows anywhere please let me know.
Tracy
Love my cars
Rover 827 Sterling SOLD
Honda CRV 2.0
Love my cars
Honda CRV 2.0
Re: bits 'n' pieces
OK, I've got two of these in the car now. One grey one with the embossed logo as above and one not looking like a Rover item, but much more sturdy and with a much higher lip around the rear half. When the weather stops freezing so badly (-15 in the morning and -7 now - should be warmer again by next weekend), I'll get them out and do some photos. When my father decides which (and if) one he'd like to have, I'll offer the other one. They certainly look very useful indeed!
Regards,
Alexander
PS: To get them I had the ABS and PGMFI light come on during the 10 or so miles I spent on the motorway - grrr...
Regards,
Alexander
Re: bits 'n' pieces
That's ok. I shall store it for you til you can collect it.dollysprint wrote:Yes please Alex, allow me to check with Brad that he doesn't mind you dropping it there for me.
Thank you
Re: bits 'n' pieces
Sorry for the delay and no piccies yet - I'll do some. We'll be going to see Brad on the first weekend in March and we'll take the 827 - so I'll be able to drop a boot liner off for you.dollysprint wrote:Yes please Alex, allow me to check with Brad that he doesn't mind you dropping it there for me.
Thank you
When this sh*t weather stops I'll pull it out of the car and take some pictures for you to decide.
Regards,
Alexander
