Shaun's Vitesse
Shaun's Vitesse
Well its been off the road too long, time to pull the covers off and get stuck in. Car has been run frequently and serviced but I haven't been underneath for a while, got a bit of a shock.
This
Soon became this
Usual bumper brackets
Been saving these a while
Car turned round a view from below
Looking a bit crusty underneath, but I have everything to replace what you can see. A lot from CHRI5E when he had a clear out, some of which he'd already re-furbed
This
Soon became this
Mk2 Vitesse Fastback
Re: Shaun's Vitesse
Hope the bits serve you well mate.
Probably along with only a couple of cars one of the only ones from the early days of the group/forum.
Re: Shaun's Vitesse
CHR15E wrote:Hope the bits serve you well mate.
Said I wouldn't get rid of it, part of the family much to my wife's dismay.
All the parts I got off you have been stripped, treated, primed and painted just need to sort under the car first, I seem to be making holes every where at the moment.
Re: Shaun's Vitesse
Rear hubs and suspension removed and started cleaning and de-rusting the back end.
I think these must be extra drainage holes above the exhaust mount
Rear exhaust shield
Rear exhaust shield
Re: Shaun's Vitesse
Be careful how far you go. I speak from experience.
Re: Shaun's Vitesse
A few area's cleaned up, treated with rust converter and zinc primed. Not a pleasant job laid on your back.
Before
The rear end of both sills where they join the rear wheel arch have rusted through in the usual place. It doesn't look too bad at the moment so will probably get cut out and patched, but if it comes to the worst I have two new sills which MG Mal had done a few years ago
Before
- TDHFastback
- Moderator
Re: Shaun's Vitesse
Its a good thread this
I like seeing peoples cars being brought back to life.Look forward to the next instalment.
Kate
Kate
Re: Shaun's Vitesse
Managed to get a few hours in at the weekend, mainly cleaning up the underside and made a start on the rear n/side sill.
Phone pictures i'm afraid, not very good quality seem to make everything look brown.
A few minutes with the angle grinder to cut the rot out
Left me with a neat hole, inner sill fine just a bit of surface rust
Made some templates out of card, then transferred them to steal and welded in. Think the sills must have been cavity waxed in the past as it kept catching fire as I was welding
Then all cleaned up and zinc primer
Also cleaned and painted centre exhaust heat shield, before and after
- Location: Leicestershire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Shaun's Vitesse
Nice neat work there Shaun, and the zinc primer will help the repairs to last.
What paint did you use on the heat shield ?
Jon
Jon
Re: Shaun's Vitesse
Hi Jon, looks better in the pics than real life but I think once its painted and under sealed shouldn't be too visible.Jon R wrote:Nice neat work there Shaun, and the zinc primer will help the repairs to last.
Jon
The heat shield had a quick wiz over with wire brush on grinder then some rust converter and Simoniz very high temperature paint,not that I think it gets that hot, its just what I had on the shelf.
Re: Shaun's Vitesse
I'm sure you'll get the finished job looking good, it's well on its way.
Are you taking your car to Longbridge ?
Re: Shaun's Vitesse
I was planning on going to Longbridge not been for a couple of years. Was hoping to take the Vitesse or failing that my MG ZT, but the Z now needs another engine and progress on the Rover is a bit slow. Will have to get some overtime in down the garage.
Re: Shaun's Vitesse
Well extract the digit and get on with it man!
Users browsing this forum: No registered users and 44 guests
