Site Maintenance
Changes to website and forum will be posted here along with upcoming events offsite that may be of interest!
guru
Site Maintenance
Post by guru » Wed May 18, 2016 11:10 am
Just to let you all know the site will be down for a few minutes as I am moving it to a new server. It should only be down for 30 mins max however I will be changing the DNS records so you may need to restart your PC and router to gain access, alternatively you can just wait for the new records to take effect.
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mercedes C300 Hybrid
2015 Mini Cooper SD
Re: Site Maintenance
Post by scoobyh123 » Wed May 18, 2016 11:40 am
When is this happening James?
guru
Post by guru » Wed May 18, 2016 12:11 pm
Very shortly, just doing the prep now..........
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mini Cooper SD
guru
Post by guru » Wed May 18, 2016 12:48 pm
All done!
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mini Cooper SD
guru
Post by guru » Wed May 18, 2016 11:22 pm
Oops, about half an hour after completing the work on the site the database server on our hosting platform decided it had had enough and took around 20 sites down! Unfortunate coincidence however everything (including rover800.info) is back up now and should be fine.
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mini Cooper SD
Post by scoobyh123 » Sun May 22, 2016 6:02 pm
James - we seem to have lost notifications since your work on the site the other day - i don't recall getting any emails telling me new replies had been posted to threads i'm subscribed to/watching since then.
Any ideas?
guru
Post by guru » Mon May 23, 2016 12:30 am
Bloomin' e-mail notifications.......bane of my life! I've just made a change to the config that should fix them.......hopefully!
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mini Cooper SD
Post by scoobyh123 » Mon May 23, 2016 7:46 am
Thanks - i'll let you know if it works or not.
Post by scoobyh123 » Tue May 24, 2016 11:50 am
So far still no emails James! Sorry if it seems like i'm jumping on this quickly but last time it seemed to drag on forever and my line of thought is it's probably easier for you to find what's wrong now rather than later. :D
Users browsing this forum: No registered users and 18 guests
