will be going to Hartley wintney in the morning and Brooklands in the pm both a good variety of cars
https://www.tripadvisor.co.uk/ShowUserR ... gland.html
http://www.classicshowsuk.co.uk/classic ... .asp?id=35
will be in the maestro.. regards ricky
brooklands new years day
- thamestyres
Re: brooklands new years day
It says the show is for pre 1986 cars only...
Just a heads up for most 800 owners
That's all 800s out of the running then Dean, all XJ40s too. Just about scrape in with a 213 shape Rover or an SD1, Triumph Acclaim, early Maestros/Montegos, Ambassador/Princess but i think that's ageist meself.deano wrote:It says the show is for pre 1986 cars only...
- Location: Hampshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Will be at the Pheonix with the mini and the mustang. I'll look out for you.thamestyres wrote:will be going to Hartley wintney in the morning and Brooklands in the pm both a good variety of cars
2x Mk1 827 Vitesse Fastbacks
3x 825 Coupe
Mk1 827 Sterling Saloon
825 Sterling Saloon
825 Sterling Fastback
820 Vitesse Coupe
820 O Series Mk1 Fastback.
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
