Its amazing who you meet sometimes!
Went to pick up a set of 17in Vitesse alloys this morning, near a place where once stood a factory known as Standard Triumph, Canley. For those that don't know, Canley ceased car production around 1980/81 as the Dolomite was allowed to die and TR7 production moved to Solihull.
By 1982 Roy Axe had set up the new design studios at the Canley site so it was effectively the birth place of 800, many interesting things went on there prior to Gaydon coming on stream.
Anyway got chatting to the seller, thinking he must have had an 800 given that he was selling the alloys, no he had them fitted to a Honda Accord, same PCD. He did then happen to mention that he owned 8 800's back when they were new from 1990-98 "so you know the cars well then" I said "oh yes I was Tony Ponds engineer!" talk quickly turns to the Isle of Man. For years there has been debate about just how modified that car was and now I know. Suspension, brakes and tyres were modified, but not massively so, the engine was completely standard, in fact the engine came out of Tony's everyday company 827 a few days before! Wyn Mitchell it was a pleasure to meet you, sorry I took up a lot of your afternoon chatting!
Re: Its amazing who you meet sometimes!
Small world.
Agreed small, but sometimes very rewarding and interesting as Dave had the good fortune to find out today.
Look forward to hearing more on this Dave. I wonder if he could shed any light on my Vitesse which was reported belonging to a Rover test driver and very good friend of said Mr Pond.
Very interesting tale Dave - did he give you any specifics on the suspension mods? I've heard 26/21 front/rear anti roll bars, uprated and lowered springs and shocks (but only slightly over Vitesse standard of the time so probably the same as later Vitesse models) and I don't know what was done to the brakes.
- neo
- Location: caddington beds [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
He has finally sold the wheels then I spoke to him at the Longbridge meet a few years ago from what I remember he said the car was pretty much stock apart from tyre and suspension set up.
tony
Dave he says he has the specs somewhere and when he finds them I can have them. Suspension tweaks were pretty much along the lines of later Vitesse spec and brakes he remembers having trouble with the 285mm discs warping but the pads were an uprated material.scoobyh123 wrote:Very interesting tale Dave - did he give you any specifics on the suspension mods? I've heard 26/21 front/rear anti roll bars, uprated and lowered springs and shocks (but only slightly over Vitesse standard of the time so probably the same as later Vitesse models) and I don't know what was done to the brakes.
Yeah stickier tyres and the mild tweaks mentioned above.neo wrote:He has finally sold the wheels then I spoke to him at the Longbridge meet a few years ago from what I remember he said the car was pretty much stock apart from tyre and suspension set up.
That's what i thought Dave, thanks!dollysprint wrote:Dave he says he has the specs somewhere and when he finds them I can have them. Suspension tweaks were pretty much along the lines of later Vitesse spec and brakes he remembers having trouble with the 285mm discs warping but the pads were an uprated material.scoobyh123 wrote:Very interesting tale Dave - did he give you any specifics on the suspension mods? I've heard 26/21 front/rear anti roll bars, uprated and lowered springs and shocks (but only slightly over Vitesse standard of the time so probably the same as later Vitesse models) and I don't know what was done to the brakes.
- BlueRover
It also had a straight through exhaust and no rear view mirror.
Let's face it - he won't really need a rear view mirror at 150mph and it all saves weight.
