New Purchase
xpuffin
New Purchase
Post by xpuffin » Sat Oct 28, 2017 8:13 pm
Just bought this on EBay.
Collect it Thursday, will report on it when it's at home.
2x Mk1 827 Vitesse Fastbacks
3x 825 Coupe
Mk1 827 Sterling Saloon
825 Sterling Saloon
825 Sterling Fastback
820 Vitesse Coupe
820 O Series Mk1 Fastback.
deano
Re: New Purchase
Post by deano » Sat Oct 28, 2017 8:21 pm
Thought you were after a desiel
xpuffin
Re: New Purchase
Post by xpuffin » Sat Oct 28, 2017 8:47 pm
I am.
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
BlueRover
Re: New Purchase
Post by BlueRover » Sat Oct 28, 2017 11:26 pm
That's a: very nice and b: very rare.
Look after it.
TomSaintJames
Re: New Purchase
Post by TomSaintJames » Sun Oct 29, 2017 8:20 am
Congrats, looks like a cracking car!
Re: New Purchase
Post by scoobyh123 » Sun Oct 29, 2017 10:08 am
Crikey Jez, i thought they were extinct by now! :shock:
Certainly looks to be in very nice condition, the 8 valve "O" series is pretty much unburstable as well, just a bit underpowered in the 800 bodyshell. If the carb dashpot needs topping up, try using ATF instead of engine oil, you'll be surprised at the improvement! :wink: :D
rovercoup
Re: New Purchase
Post by rovercoup » Sun Oct 29, 2017 5:23 pm
Looks a really nice condition car on the outside and the engine still has the original paint still in tact. Lovely purchase and very green with envy.
Enjoy it and share with us the pics when you have chance.
Nuts4my827
Re: New Purchase
Post by Nuts4my827 » Mon Oct 30, 2017 8:54 am
DAYUM that looks good!!!!
xpuffin
Re: New Purchase
Post by xpuffin » Sat Nov 11, 2017 4:33 pm
Well, not had much time to get some good daytime shots but I have had a good look round the old girl. Seems like a pretty rust free body and it's certainly been someone's pride and joy in the past. (Not the vendor though as the car is grubby and unkempt) Expansion tank was Fubar but I have a few so, no problem. Sadly the head gasket is gone also so I'm going to need to source one of those plus a rocker cover gasket and inlet and exhaust gaskets as well but I'm not having much luck finding a supplier without knowing exactly which types I need.
I shall spend a few days tinkering over the coming weeks and keep you all posted, but I like it, the simplicity of it is quite refreshing.
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
Re: New Purchase
Post by scoobyh123 » Sat Nov 11, 2017 5:56 pm
Are you absolutely sure the HG is dead Jez? The M-series was prone to mayonnaise moreso even than the "O" series and definitely more than the T series.
A head gasket set should have all the gaskets you need if so and is probably cheaper than buying them individually.
MPi M series :
http://www.ebay.co.uk/itm/HEAD-GASKET-S ... SwH09ZIvnw
SPi M series :
http://www.ebay.co.uk/itm/HEADGASKET-SE ... 2325609079
However this one looks like it has the rocker cover gaskets as well :
http://www.ebay.co.uk/itm/Rover-800-820 ... Swo8hToWd6
If all else fails, have a look at all of them listed on fleabay :
https://www.ebay.co.uk/sch/i.html?_odkw ... t&_sacat=0
Hope that's some help to you one way or t'other! :wink: :D
xpuffin
Re: New Purchase
Post by xpuffin » Sat Nov 11, 2017 9:22 pm
Wow, thanks Dave, most helpful. Still don't know much about the engine so assumed all the injection options wouldn't work. Yes it's deffo the head gasket as on the front right edge a small puddle of oil appears on the head gasket overlap after a few minuites running. It looks like the hog has been replaced recently so in guessing either badly or no skim.
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
xpuffin
Re: New Purchase
Post by xpuffin » Sat Nov 11, 2017 9:25 pm
Dave, it's an O series engine, do the M series headgaskets fit.
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
Re: New Purchase
Post by scoobyh123 » Sun Nov 12, 2017 12:12 am
Crikey Jez, that is a rare one! With the carburettor? :o :shock:
The M series almost certainly won't fit unless you fit an M series head to it which changes the car completely.
However a bit of digging found this :
https://www.rimmerbros.co.uk/Item--i-LVQ701162EVA
It's NLA but the important bit is the HG set also fits the Montego range :
That's all of them including the 1275cc, 1600cc, 2000cc ("O Series) in carb, EFi and Turbo form) and this one looks like it should be the right one for you :
https://www.ebay.co.uk/itm/MONTEGO-2-0- ... SwLyBZzPEs
If you're right and the head has been off, worth investing in a set of head bolts, a skim and a tap to clear the bolt holes out as well. If memory serves correctly it's an oddball size of M11 x 1.5 but that was on a 91/K 420GSi, not sure if the earlier "O" series used metric head bolts or still had UNF or something. Worth double-checking once you have a head blot out.
Also check your radiator - i had a 2.0 EFi Montego that cooked the head because the rad was blocked. Dropped an M-series (with a clear rad) in it from my first 820Si, literally a spanner job apart from making one engine mount! :wink:
Nuts4my827
Re: New Purchase
Post by Nuts4my827 » Mon Nov 13, 2017 7:19 am
Here you go:
ALL the gasket bits you could possibly want:
http://www.jayar.co.uk/engine-parts/Eng ... Parts.aspx
Used Jayar to rebuild of the engine and drivetrain on the 827 Stirling for my friend. SO much stuff for our cars.
Randomly though, they dont list the ball joints for my Vitesse, but they're the same as all cars :)
Re: New Purchase
Post by scoobyh123 » Mon Nov 13, 2017 10:37 am
Nice find Phil! :D Think i've narrowed it down a bit more :
http://www.jayar.co.uk/engine-parts/eng ... Parts.aspx
If that doesn't go straight to the HG set for the "O" series, here's what is on the page :
Brand: BGA Group
Part Number: HK3360
Head Gasket Set
820 2.0 (1986-1991) ,
Years Body Fuel CC Cyl Valve Cam Trans
05/88-09/90 Hatchback Petrol 1994 4 8 OHC FWD
£56.68
Inc VAT
It's lost the tabulation somewhat but it's for the 4 cylinder, 8 valve OHC which is the "O" series by any other name! :wink: :D
Users browsing this forum: No registered users and 44 guests
