Mk1 Windscreen Scuttle Panel
- projectxx
- Location: central scotland [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi All,
I'm in pretty desperate need of a seviceable Windscreen Scuttle, I'd consider minor repair req/re paint, just removed mine and after poking about it now looks like the Titanic , I intended to repair but...., are Mk2 different?
Regards
Regards
Re: Mk1 Windscreen Scuttle Panel
Where abouts are you ?
I may just know someone who still has a spare
doh !!!
couldnt be further away
The fella who has it is in Kent and i`m in London .
- projectxx
I'll keep it in mind, thanks. I'm now part way through repairing the existing one
- rovercoup
Yes MK1 & MK2 are different and although they are identical in length and overall shape the MK1 has two pillars for the windscreen wipers to rest against.
yes they are also about an inch deeper
- BlueRover
I'm surprised no-one has made a pattern part for these as there seems to be a demand for them, like the sills.
I suppose I could measure my last new one for size and a sheet metal worker could make them.
If you do that Gordon, can you do the same with a Mk2 scuttle please? Don't forget it's not just a flat piece of metal and there's a couple of compound curves in it.
I've got two or three Mk2 scuttles sitting around that I really should sell, should anyone be in need
- mjc9967
Brand new?
- mjc9967
Incidentally a Mk1 scuttle goes perfectly nicely on a Mk2. The stalks sit invisibly beneath the bonnet edge. Look closely at my V reg pics
No, not new. But no rust. Probably a few marks from being lugged from shed to shed, but not a glossy black or anything.
Users browsing this forum: Majestic-12 [Bot] and 6 guests
