Scuttle panel, the metal full width one
n1tr0_9
Post by n1tr0_9 » Sat Jul 21, 2018 10:34 pm
Wanted, metal scuttle panel that runs the full width of the base of the windscreen and covers the base of the windscreen. Needed for a 1997 fastback.
Also need the metal plate that goes above the brake servo.
Manual leather gear knob.
Dimpled leather steering wheel for a vitesse.
R750 cd changer controller stereo
Re: Scuttle panel, the metal full width one
Post by scoobyh123 » Sun Jul 22, 2018 3:38 pm
Can't help with the first two, might have a steering wheel though.
As for the gearknob, this was covered in another thread some time back and from what i remember, the Rover ones are NLA at Rimmers, secondhand ones are scarce (especially in good condition) so what most people have done is used ebay :
https://www.ebay.co.uk/itm/Universal-5- ... 2250054050
https://www.ebay.co.uk/itm/Black-Blue-L ... 1262197594
https://www.ebay.co.uk/itm/new-Universa ... 2925873926
A few to choose from there - search for Range Rover or Freelander manual gearknob, they used the same ones originally i believe. They're listed as different part numbers but fairly confident they're the same under the parts label. :wink: :D
I've got one or two stereos with CD changer control, not sure of the exact model numbers though.
Post by mercedade » Mon Jul 23, 2018 8:36 am
Whereabouts are you based? I'm in Manchester/Stockport, and have a couple of scuttle panels - but transport will be a bit of an issue!
n1tr0_9
Post by n1tr0_9 » Mon Jul 23, 2018 3:52 pm
Excellent. If I get a decent photo of my stereo can you take look and see if you have a match? And have you got the codes?
James
n1tr0_9
Post by n1tr0_9 » Mon Jul 23, 2018 3:53 pm
Oh and can you check for a steering wheel. I need s late airbag one with the dimpled leather.
n1tr0_9
Post by n1tr0_9 » Mon Jul 23, 2018 3:55 pm
n1tr0_9
Post by n1tr0_9 » Mon Jul 23, 2018 3:57 pm
I’m in the south east! Bummer. I occasionally travel up your way so will keep you in mind. Don’t suppose you are going to the Peterborough show on Sunday?
Post by scoobyh123 » Mon Jul 23, 2018 5:05 pm
James
I'm fairly sure i've got the code, if i haven't then it's just a box so won't be any help to you. What's the problem with your existing stereo?
I haven't found the steering wheel yet but i did find a pair of Mk1 Vitesse wheel spats, i'll have a look soon at the Stereo i've got to see which model it is. :wink: :D
rovercoup
Post by rovercoup » Mon Jul 23, 2018 7:12 pm
Hi nitro,
I have a spare scuttle, a steering wheel and radio with code and will be attending the BMC show in my black coupe.
If you don't get parts by then let me know and I can bring them with me. I also have a reasonable leather gear knob too.
Steve
n1tr0_9
Post by n1tr0_9 » Mon Jul 23, 2018 8:09 pm
This is the stereo I need. I think its an R750, but importantly it says CD controller across the top. I think there were other similar looking units but that couldn't control the CD player.
deano
Post by deano » Mon Jul 23, 2018 8:45 pm
R960 It should say it on the red lettering at the top there .
There is also a R950 with only 5 preset buttons instead of 6
There was a R750 but i think that may have been without the CD funtion
Post by scoobyh123 » Mon Jul 23, 2018 9:26 pm
That is as Dean says an R960 James and coincidentally the same as the spare one i have. Only thing is i can't find the code for it at the moment, i think i know the code but need to refit the buttons to try it!
If it doesn't work you have a good offer from Steve for a radio with code, steering wheel and a gear knob and i believe a scuttle panel as well on your scuttle panel thread. :wink: :D
n1tr0_9
Post by n1tr0_9 » Tue Jul 24, 2018 1:47 pm
Just checked and your right it is an R960. Anyone got one in working order with the code?
Post by scoobyh123 » Tue Jul 24, 2018 2:31 pm
Hi nitro,
Steve
I think Steve has the answer to your prayers James! :wink: :D
Post by mercedade » Fri Jul 27, 2018 8:03 am
I'm afraid not, car shows have never really been my thing. I like having a wander round the local ones where you get a proper weird mix, but never managed to drag myself further than a few miles!
