Re: 1994 BRG Vitesse Fastback
Post by Manalishi » Tue Jul 21, 2020 5:42 am
Wow! Everything is as new or better! Is this maybe the best looking 800 out there? Very impressive work you are doing!
Austin Seven Ruby -36
Rover 216 coupe -93
Fastback
Post by Fastback » Tue Jul 21, 2020 9:11 am
Steady on Henrik, you're going to upset a lot of folk with that kind of talk. :lol:
But surely it must be the most modified. Excellent stuff.
820Vitesse
Post by 820Vitesse » Tue Jul 21, 2020 12:51 pm
Thanks for the comments Dave, Adrian, Henrik and Mark.
Thanks Henrik, a huge compliment but it is so far from original not sure it deserves that title, it does have plenty of dents and scratches that do not show in the pictures. I plan to get the sun roof opening filled in and body straight and resprayed one day.
Post by Manalishi » Tue Jul 21, 2020 1:00 pm
Haha ok, well you get what I mean. It’s so clean You could eat your strawberry pie straight from the floorpan! :D
Rover 216 coupe -93
820Vitesse
Post by 820Vitesse » Wed Jul 22, 2020 9:52 pm
The exhaust rear sections and mounts are finished.
Car still up on stands when I took this but it looks something like this from above.
For the more sensible rear silencer I tacked together a selection of bends and short straights to get round the fuel tank and rear suspension
Test fit with new silencer
Now fully welded and next to the optional side exit
Other news, adjustable rear turrets are fitted, replaced a worn rose joint on the rear ARB, adjusted the ride height a little lower all round, adjusted the front and rear toe, still need to rig something up to check overall alignment or get it on a laser aligner for camber and caster checks.
I started the car for the first time in 9 months, with the side exit fitted it is much much to loud, sounds great but the car is not fast enough to justify that much noise. So before putting the car back on its wheels I swapped it for the Vibrant rear silencer, still noisy enough but more appropriate and probably still over track day noise limits.
Post by scoobyh123 » Wed Jul 22, 2020 10:22 pm
Nice!!! :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Post by Marc-827-Vitesse » Wed Jul 29, 2020 7:05 pm
My goodness. Looked at all the work with open mouth. Like the rear silencer a lot. ;)
820Vitesse
Post by 820Vitesse » Thu Oct 22, 2020 2:51 pm
Haha thanks Marc, thanks Dave. I really appreciate your comments and apologise for the very late reply. A short internet break turned into a few months but work has continued on the car.
I changed the 4 point harnesses to 6 point by adding crutch belts. The floors needed strengthening for 2 extra harness mounts each side so after some head scratching it was either construct two complicated box sections to weld inside the car or something under the floor.
I opted for under the floor for simplicity but they have to be removable for fuel pipe access.
part built plates Image
Test fit Image
and zinc plated for protection.
820Vitesse
Post by 820Vitesse » Thu Oct 22, 2020 2:56 pm
While the seats were out it was also a good opportunity to improve the seat mounting points.
These little captive nut inserts are to go inside the front seat mount crossmember. As well as adding strength they will save me a lot of time balancing a nut and washer on the tip of a finger while hanging over the door bars holding the seat and trying to thread a bolt.
Sat on top in the pictures these will go inside the crossmember
Ready to weld
Welded
Post by scoobyh123 » Thu Oct 22, 2020 3:09 pm
More excellent work there Jim! A little confused about the seat mounts, they look very similar to the OE seat mounts or am i missing something?
820Vitesse
Post by 820Vitesse » Thu Oct 22, 2020 3:27 pm
Thanks Dave, the original seat rails bolt into a double skinned captive nut at the front of the box section but for my bucket seat mounts I had to drill and bolt down through the top of the single skin area of box section as pictured. Now with these little plates added it should be as strong as the original factory design, hope that makes sense.
Post by scoobyh123 » Thu Oct 22, 2020 6:30 pm
Thought it would be along those lines JIm, thanks! The do look more substantial than the original mounts but then the original mounts weren't designed for hammering round Castle Coombe, Thruxton, Brands Hatch or wherever you take it. :wink: :D
820Vitesse
Post by 820Vitesse » Mon Oct 26, 2020 3:26 pm
A battery isolator switch has been on the to do list for a long time so several templates and many changed plans later I decided next to the front passenger seat was the best location.
It needs to be very secure so I used 6mm aluminium plate.
Much sawing and filing later I had the basic panel
To mount the panel I fitted longer bolts to the gear linkage rear mount
Test fit with a slight bend to the panel and switch installed
While re-routing the battery cable I noticed some old wiring needed tidying which led from one thing to another then before I knew it the dash was out, it currently looks like this while I sort out the wiring mess I made.
Post by scoobyh123 » Tue Oct 27, 2020 7:20 am
More excellent work Jim! Are you using the resistor across the isolator terminals to provide memory feeds? If so i'd suggest fitting a fuse in series with it, just a small one of about 10-15A so if anything goes wrong you have that extra bit of protection.
820Vitesse
Post by 820Vitesse » Fri Oct 30, 2020 2:02 pm
Thanks Dave, not sure if I will need the extra wiring it is just fitted for safety in the event of a smash.
