Lovely job Marc! I had a look for that MK1 expansion tank, no sign of it at the moent but it might be buried - if i do find it i'll let you know.
Thanks! A oké, thanks for the effort so far in the search. No rush.scoobyh123 wrote: ↑Sat May 12, 2018 7:23 pmLovely job Marc! I had a look for that MK1 expansion tank, no sign of it at the moent but it might be buried - if i do find it i'll let you know.
I've been having a major sort-out and clear-out lately so if it's still there i should come across it soon - assuming it's still there of course.
I don't remember getting rid of it or selling it so hopefully i haven't forgotten it!
Last weekend during the nice weather i took my Vitesse for a trip to visit a friend.
A small milestone was reached. 115.000 km.
Nearly home i took the time to take some snaps in the parking garage of a shopping centre.
UFO sighting.
UFO sighting.
Very nice! Just about run in now as well Marc!
Cheers! Hahaha yeah i think after almost 30 years it is coming close to be run in.
By my reckoning 115000km is about 73000 miles so yes, just about run in!
By comparison i have a 1988 Volvo with nearly 222000 miles, not sure about the Netherlands but in the UK we view 12000 miles a year (20000km) as being average miles so in theory, my Volvo is low mileage for the year. That makes your Vitesse incredibly low!
By comparison, my Sterling is just coming up to 112000 miles (180000km) and my Coupé is just shy of 147000 miles 220000km) so yours is definitely low!
Yes my 827 has very low millage indeed. My Sd1 has 112.000 km and that is from 1982. Even more bizar.
12.000 miles de year is just about average here for a daily commuter i think. Holland is a logistic country so 30.000 km or sometimes 40.000 km a year is possible.
You're extremely lucky having such low mileage examples Marc, i know you give them all exercise so no problems with things seizing up.
I feel Lucky as wel!
My Rovers are not daily commuters but when i have the chance i take them out and about!
They're certainly well looked after, that's for sure!
Cheers!
I tackled the rust on the inside of the roof. In two places it became to bad to just grind it down. I cut out two small pieces. One on the left side and one on the right
At the front it was just cleaned properly.
First i coated everything with zinc.
Made some replacement steel to fill the holes.
Welding was no option because we would certain damage the paint on the roof.My friend had a good idea to use car body glue. Cleaned of the zinc coating to ensure a good adhesive.
Looking pretty good already.
a small hole in the front was closed of with the glue.
A few days later i used just a little filler.
Primer::
Colour coat:
Clear varnish:
End result. On the right side you can hardly see something has been repaired.
The left show a bit more scaring but it is all better and no more rust!
Soon i will fil the body of the roof with wax to ensure a durable result.
Primer::
Colour coat:
Clear varnish:
Cracking job there Marc and inspiration for me when i come to do mine! Only got one bit that needs "in-depth" repair and it will only need primer afterwards - might weld it as not so worried about the paint on the roof but it's very thin there so metal bond would be an ideal option!
Thanks! I am really chuffed with the result. It was a very good idea of my friend. Easy, elegant and proper!
In your case it does sound like a good idea. Glad my topic gave you some help!
It certainly did Marc! Much quicker than welding, considering i'd have to take the headlining and sunroof out to weld it! Safer as well!
