Rover 825 v6 Sterling 1998 R543 HJW
Col 2e
Newbie
Re: Rover 825 v6 Sterling 1998 R543 HJW
Post by Col 2e » Thu Oct 25, 2018 5:17 pm
Cheers Dave, I'll try the Kia Dealer.
Post by scoobyh123 » Thu Oct 25, 2018 5:47 pm
You're welcome Col - if they're as friendly and helpful as they are round my neck of the woods you should stand a good chance.
That said, i've mainly been after parts but although they could get them quicker than other places, they weren't quite as good on price but better than most main dealers! :wink: :D
Col 2e
Newbie
Post by Col 2e » Mon May 13, 2019 12:49 pm
Afternoon All, Kia Dealer Not at all helpful on previous, so I saved up and bought the Kit....Next problem, Jimmy the Mechanic has informed me that to Change the timing belts, he needs Two 'Cap Ends/ Blanking Caps', Tried several contacts, no luck. Any ideas of possible suppliers or even the right name for these ????? Cheers in advance, Col.
Post by scoobyh123 » Mon May 13, 2019 1:07 pm
Col - can you find out what Jimmy means by "blanking caps"? :shock: :?
Col 2e
Newbie
Post by Col 2e » Mon May 13, 2019 3:00 pm
Jimmy explained to me that stripping down the engine to change the belts , there is a rubber 'Cap end/Blanking Cap' at each end that need replacing on the Block. approx. 2" dome shape 50mm Dia. Any help Dave ??
Post by scoobyh123 » Mon May 13, 2019 5:51 pm
Is this what he's referring to Col?
https://rimmerbros.com/Item--i-LUC100151
They are the exhaust cam oil seals so are on the head, not the block although having seen a couple of KV6s, it's an understandable mistake to make.
It might also be wise to renew the thermostat while he's doing it, the inlet manifold has to come off (you'll need an inlet manifold gasket set as well) and the thermostat lives under it as far as i know. Either way, the inlet manifold has to come off to change the 'stat and the pipework has a habit of breaking so i would say it would be a wise move to renew it while everything else is in bits.
According to RAVE, the timing belt interval on the KV6 is 96k miles so you've got a bit of time to wait for the next one, 8 years or 96k miles.
Col 2e
Newbie
Post by Col 2e » Mon May 13, 2019 7:57 pm
Once again, Many Thanks Dave, Believe these to be the bits, now ordered from Rimmers.. Fingers crossed.
Post by scoobyh123 » Mon May 13, 2019 8:15 pm
Hopefully those are the right bits then - reading through the method on RAVE the old ones have to be removed for fitting a service tool to the end of the exhaust camshafts.
I can see a different way of doing things but your Jimmy is obviously doing the textbook method so i won't interfere! :wink: :D
Col 2e
Newbie
Post by Col 2e » Mon May 13, 2019 8:36 pm
I don't know what method Jimmy is following Dave, but he won't start anything that he can't complete without the right parts. That's the main reason I return to him, plus he knows what he's doing Mechanically, something that I will attempt if its got 'novice' or one spanner. anything more technical I call for International Rescue. Cheers once again, any Rover 800 get together this year ?? I've got to make the most of being retired....
Post by scoobyh123 » Mon May 13, 2019 10:57 pm
Not sure of what get togethers are happening to be honest. The BL/BMC Rally at Peterborough seems to have died a death, i believe there's another around Spetember time at Milton Keynes but not too sure.
neo
Post by neo » Tue May 14, 2019 6:40 am
There is a video that I put on you tube many years ago shows you how to replace both sets of belts
https://youtu.be/2fFx8SPiTSc
The show Dave mentioned at Milton Keynes was very good last year worth a visit.
tony
Post by scoobyh123 » Tue May 14, 2019 6:59 am
Good video Tony but having the engine on a stand makes it look easy! :P :lol:
Have you got a link for the MK show this year or know if it's actually happening?
neo
Post by neo » Tue May 14, 2019 8:29 am
Mk show is organised by Tanya she normally puts something on here nearer the time. Like I said it was a good one worth a visit.
tony
Post by scoobyh123 » Tue May 14, 2019 8:40 am
Thanks, have you got any photos from the last one?
neo
Post by neo » Tue May 14, 2019 8:41 am
Bl autumn rally mk Sunday 29th September
http://www.miltonkeynesmuseum.org.uk/
tony
